Tab notation
fast eddie
Tab notation
Post by fast eddie » Sat Nov 25, 2017 5:21 am
I am using music notation software muse score 2 to create sheet music notes. Is there a way to add Tablature ?
Fast Eddie
Cordoba C 10 Cedar
1974 Hernandis
KlaBueBaer
Re: Tab notation
Post by KlaBueBaer » Sat Nov 25, 2017 10:43 am
Hi Eddie,
have a look here: https://musescore.org/en/handbook/tablature
It should help.
Lakewood M-32G --- Aria MH 100 --- Hoyer Grand Concert --- Crafter Vintage ---
MuseScore --- GuitarPro --- SmartScore ---
Paul Janssen
Re: Tab notation
Post by Paul Janssen » Sat Nov 25, 2017 12:50 pm
Hi Fast Eddie,
If you have already scored your piece(s) in standard notation then a simple way to add Tablature is as follows:
Select Edit > Instruments (this will open the instruments panel)
Click on >-Plucked Strings then Click on -Classical Guitar (Tablature) and click on the Add button
Click OK (this will add the TAB to your score)
Select all the bars in your original notated score and copy them
Click on the first Bar of your Tab and Paste. This will create a best estimate TAB.
Once you have done this, you will need to go through the tab to make sure it has selected the correct strings you wanted. If it hasn't, you can select the note within the tab and drag it to the correct string.
Good luck.
-Paul
fast eddie
Re: Tab notation
Post by fast eddie » Mon Dec 04, 2017 3:50 am
Thanks. This is a big help.
Fast Eddie
Cordoba C 10 Cedar
1974 Hernandis
Return to “Public Space”
