Question about music writing software
Re: Question about music writing software
Post by pogmoor » Tue Aug 08, 2017 9:12 pm
Adrian Allan wrote:
Tue Aug 08, 2017 7:34 pm
...Finally, being teamed with Steinberg, there is a longer term goal of having one program that can also function as a midi sequencer and an engraving software. With Dorico, you are investing in this future, and lots of people have complete confidence in a team that in terms of their knowledge of engraving is pretty unbeatable.
I'd agree with that. Providing Steinberg continue to support the development team's work I think Dorico is likely to be the future in professional music engraving. However, to go back to the OP's question, any of these applications, including Musescore, will do a good job for the average user.
Adrian Allan
Post by Adrian Allan » Tue Aug 08, 2017 10:06 pm
Yeah - I will stick with Sibelius for now. It does everything I need, and I have very little interest in graphic scores or anything like that. For tonal composers it is perfectly fine.
Apparently they tested out some of the functionality of Dorico with Ferneyhough, and it if it can cope with that, then it's very impressive.
Sibelius does still have some annoying glitches, though, such as messing up something as simple as triplets in certain cases (I think when they are tied). So far the new development team have not been very responsive, and since Daniel and co left, the improvements have been very minor in the new versions, and plenty of loyal customers are losing their patience.
D'Ammassa Spruce/Spruce Double Top
fast eddie
Post by fast eddie » Mon Sep 18, 2017 3:46 pm
Just downloaded a free music software package called musescore, version 2.1. I hate to read directions, but I did read just a minimum for this, and seems to do everything that I need it to do. I also read that musescore is similar to UNIX, which the source code is in the public domain. I used it to write the notes from a TAB version of Hallelujah. The problems that I encountered were (1) The time signature is 6/8 and in some measures there not 6 eighth notes, (2) the playback feature sounded very good but obviously the song is incomplete. Any problems I encountered were solved by an internet search, e.g.at first I could not delete a note, but the internet solved this. If I exit the edit mode and place the cursor on the note to be deleted, just hit delete or backspace, and it worked.
I don't plan to compose until I get a lot better at playing. So there will be no composed pieces by me in this lifetime. So not sure what else I will use musescore for, but it seems to be fairly good. Just my $0.02
Fast Eddie
Cordoba C 10 Spruce
Cordoba C 10 Cedar
1974 Hernandis
DCGillrich
Post by DCGillrich » Tue Sep 19, 2017 10:04 am
I use Lilypond, which is uses the General Public License (GPL). It is very flexible, and can do almost anything that Musescore, Finale and Sibelius can do (I also have version 5.2 of the latter). Lilypond can easily handle guitar notation such as string numbers, fingering, etc. It can handle quite obscure notation if necessary. It is easy to turn tablature on and off. Yes, you have to enter the notes and duration, etc., using text. However, with practice, that becomes quite a quick process. I find the output looks very good without adjustment, but there is a lot of information on how to tweak the look, and to manage clashes when the music is very dense. It is also possible to create libraries of standard notation specific to particular instruments, and macros to enter frequently used commands using abbreviations.
Because Lilypond uses text input, I use the GPL licensed Frescobaldi as a GUI, which prepares a pdf output and displays it in a separate window. Clicking on notes in the pdf window highlights the text note, and vice versa. It also prepares a midi file (if turned on), which can be played back. I use VirtualMIDISynth as the midi playback device (rather than the default windows player)--that way different sound files can be used. RealFont_2.1.sf2 gives a very realistic classical guitar sound.
IMO Lilypond/Frescobaldi is a good option; the programs are frequently updated, and they are free!
Cheers... Richard
PeteJ
Post by PeteJ » Tue Sep 19, 2017 12:26 pm
I like Musescore a lot and find it hard to believe it's free. Not had one problem with it yet that wasn't just my incompetence. But I haven't used any other score-writing software. I think the upgrade to v2 was important and it may not have been so good before this.
PeteJ
Post by PeteJ » Tue Sep 19, 2017 12:27 pm
Duplicate deleted
R.V.S.
Post by R.V.S. » Wed Sep 20, 2017 2:18 am
There's also Noteflight, a web-based notation app. it's very easy to use and has more than enough features for classical guitar compositions. I also like the idea of having my compositions saved in the cloud so that I can access them from anywhere and I don't have to worry about losing them to a computer failure.
fast eddie
Post by fast eddie » Sat Sep 23, 2017 12:31 am
Thanks everyone for these helpful suggestions. Much appreciated.
Fast Eddie
Cordoba C 10 Spruce
Cordoba C 10 Cedar
1974 Hernandis
fast eddie
Post by fast eddie » Sat Sep 23, 2017 12:48 am
Doe
Does anyone know if it's possible to convert a TAB file to notes with music software ? This would be so helpful and save much time. I have begun to use musescore 2.1 but really don't know if it has this capability.
Fast Eddie
Cordoba C 10 Spruce
Cordoba C 10 Cedar
1974 Hernandis
Post by pogmoor » Sat Sep 23, 2017 7:24 am
MuseScore does have the capability to convert tab to notes (as do other score writing applications). The problem is that you then need to edit the output as tab doesn't convey the note durations in inner voices.
asmodeus
Post by asmodeus » Sat Sep 23, 2017 4:17 pm
If you're looking for software specifically for notating Guitar, also have a look at Guitar Pro. It's not as flexible as Finale or Sibelius, but based on my personal experience it's much easier to learn.
ToniLeo
Post by ToniLeo » Wed Mar 14, 2018 4:47 pm
I'm a bit "old school" and used to edit scores that I bought in a music store with a pencil (f. e. changes in fingering).
I also have a lot of xeroxed scores that I copied in libraries etc. Finally it was just too much paper to cope with. It took too much time to find a particular score. And in my living room (where I practice) there were just piles of scores everywhere. Sometimes when a pile fell down it took hours to restore the original order.
So I finally decided to scan all my printed scores, some of which are 40 years old, and saved them as PDF. On my harddisk there are also tons of PDF scores that I downloaded from various web locations, now about 3000 pages.
To perform and/or to practice, I now use a monitor to display the scores and a foot switch to go to the next page.
The problem is that I can't edit the scores anymore with a pencil (fingering etc.). What I am looking for is a program that is able to convert PDF scores into scores that I could edit with a PC.
What would be the best option to do this? Finale, Sibelius, or would the free Musescore just do the job?
Yesterday I downloaded a 30-day trial version of Sibelius, but a subprogram to import PDF scores was deactivated in this free version. I also didn't like the "Micky Mouse" layout of Sibelius. It looks like being programmed for kids.
Arash Ahmadi
Post by Arash Ahmadi » Wed Mar 14, 2018 5:02 pm
I agree more or less with the thorough post of Stevel. I have tried most of the music notation software and for me Finale is the most professional. I used Finale for notating solo instruments to my concerto for guitar and orchestra. I haven't tried Dorico that Allan has mentioned yet but it sounds promising.
To send light into the darkness of men's heart, such is the duty of the artist. (Robert Schumann)
Salvo
Post by Salvo » Wed Mar 14, 2018 5:38 pm
You may try a music OCR package such as Photoscore; works very well if your original is high quality. Just save the output as an .xml file and import it intio Finale or Sibelius etc.
If your original pdf was produced with a software notation program and is still in vectorial form, you may have luck with PDFToMusic. Again, go through the .xml thing.
ToniLeo
Post by ToniLeo » Thu Mar 15, 2018 4:06 pm
Thank you, Salvo, I'll try that.
Return to “Public Space”
