Papathanasiou, Vangelis - Chariots of fire
This forum is for our discussions on any classical guitar works. Regardless of whether these works are still under copyright, we can illustrate our discussions with extracts to a maximum length of 8 bars or 30 seconds, using attached audio files (mp3, wav or wma) or video files (mov or wmv). Only attached files are permitted. Links to audio and video files are not allowed.
This forum is for our discussions on any classical guitar works. Regardless of whether these works are still under copyright, we can illustrate our discussions with extracts to a maximum length of 8 bars or 30 seconds, using attached audio files (mp3, wav or wma) or video files (mov or wmv). Only attached files are permitted. Links to audio and video files are not allowed. However, we can say in our posts "you can hear a model interpretation by such and such a guitarist on such and such a site".
This forum serves as a place of mutual help if we are stuck on a technical or musical difficulty, whether the problem stems from the notes, the rhythm, the dynamics, or the fingering. We can post several successive versions of the extract, as our work on it progresses. This will serve to help not only the member who is presenting his work, but also indirectly the dozens of other members who are having the same issues with the same passage, but who don't have the equipment or the technical knowledge to post a recording.
As a rule there should be just one topic per work. If several discussions arise on the same work, the moderators will merge the threads together.
sxedio
Post by sxedio » Fri Nov 03, 2017 10:58 pm
Chariots of fire, playing from the piano score, 6th in D.
(Gr) (En) (very little Fr)
Elías López Cruz
Re: Papathanasiou, Vangelis - Chariots of fire
Post by Elías López Cruz » Mon May 07, 2018 1:37 am
Bravo! Good performance and arrangement! How can I get the score?
Guitars: "La Valenciana" model 113 (1976), "Tres Pinos" SCG-E112 (2007), "Sergio Mercado" Ramírez replica 2011, Arturo Hernández Hauser replica (2014), Karina Mendoza Fleta replica (2016).
sxedio
Post by sxedio » Mon May 07, 2018 1:01 pm
Thank you Elias. The piano score in D flat is available e.g. on sheet music direct.
chlebik
Post by chlebik » Mon Aug 13, 2018 7:02 am
Excellent! IMHO you've grasped the soul of this piece. Very often it is played too fast and looses its beauty. Keep working!
"You got big dreams. You want fame. Well, fame costs. And right here is where You start paying. With sweat". - Fame TV Series Intro
sxedio
Post by sxedio » Mon Aug 13, 2018 10:24 am
Thank you chlebik!
Return to “Extracts of works in progress, 8 bars or 30 seconds maximum”
