Pepe Romero rectified nylon trebles - same specs for both medium and hard tension sets?
jdykes
Post by jdykes » Thu Nov 29, 2018 6:10 pm
Pepe Romero GRNM Classical Guitar Strings Rectified Nylon Normal Tension - normal tension
Pepe Romero GRN Classical Guitar Strings Rectified Nylon Hard Tension - hard tension
Is the difference in tension only in the wound basses with the trebles in each set the same?
John
jdykes
Re: Pepe Romero rectified nylon trebles - same specs for both medium and hard tension sets?
Post by jdykes » Sun Dec 02, 2018 12:00 am
I’ve contacted the PR string contact to see if they can fill me in.
Scott Phillips
Post by Scott Phillips » Sun Dec 16, 2018 7:22 am
That is common to many brands that the trebles in both the medium and hard tension sets are the same. For example, Dogal had the same trebles in their strong and extra strong tension sets.
