What is this with D'Addario EJ45-3D Pro-Arte Nylon Classical Guitar Strings?
Thomas
Post by Thomas » Wed Dec 19, 2018 2:16 pm
I am not sure perhaps it was always so but recently I used
D'Addario EJ45-3D Pro-Arte Nylon Classical Guitar Strings, Normal Tension
and all of my guitars string just in 1 month using it has become like this
What do they call this in Egnlish ?
Kent
Re: What is this with D'Addario EJ45-3D Pro-Arte Nylon Classical Guitar Strings?
Post by Kent » Wed Dec 19, 2018 2:19 pm
If you play a lot, I would call it perfectly acceptable normal wear.
soltirefa
Post by soltirefa » Wed Dec 19, 2018 2:29 pm
I believe that's your garden variety oxidation.
Thomas
Post by Thomas » Wed Dec 19, 2018 3:31 pm
I play 2 or 3 hours a day but distributed on 2 or 3 guitars I did not have this experience with other strings not too soon :) am I playing a lot recently?
And these strings are on for less than a month . Strange
Beowulf
Post by Beowulf » Wed Dec 19, 2018 3:37 pm
Fret wear on the delicate windings of the bass strings...it will increase with playing time, heavy finger pressure and fret technique which moves the string laterally.
Christopher Langley
Post by Christopher Langley » Wed Dec 19, 2018 5:27 pm
Oxidization. Rust. Normal. A little discoloration is nothing to worry about as long as they still sound good.
I have had the opposite experience to you. D'addario ej27n student strings seem to last quite a bit longer than others for me. You might try them. Lovely, warm, cheap, forgiving strings.
Another thing that helps is playing with clean hands and wiping the strings down. I think this has made a big difference for me.
It's likely your strings have always done this, you probabaly just started noticing. Don't replace them until they actually die!
Let there be songs to fill the air.
