Carbon strings pulling through
Baloo
Post by Baloo » Tue Dec 25, 2018 12:36 pm
I thought I'd try carbon strings and had got them all on and was tuning up to pitch when the high E snapped, or so I thought. After opening a new pack I realised that actually it had just pulled through at the bridge. I tried again and same thing happened. Is there something different you need to do with these strings? I have a figure of eight at the bridge. Do I just need to add a couple of turns, or is there more to it than that?
TIA
Chuah Hui Hsien
Re: Carbon strings pulling through
Post by Chuah Hui Hsien » Tue Dec 25, 2018 1:08 pm
You can wipe the E, B, G with slightly moist towel, and melt a ball end at each string before you tie them on the bridge. Carbon strings tend to be more slippery than nylons. That is why I avoid using them on my new guitar.
And you can attach a cardboard lengthwise at the brigde, better to use low tack tape if you have French Polish top.
Tune up your string or bring up the pitch gradually. Check against the ties as you tune. Make sure they didn't slip.
Jack Douglas
Post by Jack Douglas » Tue Dec 25, 2018 2:01 pm
TIA
Carbon strings are very slippery, therefore they always need extra wraps at the tie block when installing them. For the e string thread the end at least 4 times back through. 4 times for the b and 3 times for the g string. Leave at least an inch and a half of excess and hold your hand on the end as you tighten the string so you can feel it if it starts to slip. Always use a cardboard or other type of soundboard protection and leave it there until you are certain the string tie is secure.
Baloo
Post by Baloo » Tue Dec 25, 2018 5:47 pm
Thanks. I melted the ball ends and added a couple of turns - so far so good. Not sure how reliable those ball ends are though, full of crud from the matches. I will hold the string below the match next time. I also just read that you should always wind the strings to the outside of the bobbins. I have been doing it whichever way gives the straightest line to the nut.
I hadn't thought to look for damage, but now I do there are two dings. They're pretty deep but I'm guessing as long as they don't actually go through they're only going to be cosmetic.
vesa
Post by vesa » Tue Dec 25, 2018 6:52 pm
Hi baloo
No worries.
Almost everybody has done that mistake
when stringing the guitar for the first time with carbon strings.
(how do I know) :D
Mine is 1st and 2nd 4 times around 3rd 3 times
and that is because I have had 2nd to slip too.
Vesa
Vesa Kuokkanen
Antonio Marin nr. 813 1995 (Bouchet)
Vesa Kuokkanen 2016
Post by joachim33 » Tue Dec 25, 2018 10:41 pm
There have been reports that melted ball ends on carbon strings can break of. Also I don’t like open flames next to my guitars. A stopper knot seems the better choice to me.
Chuah Hui Hsien
Post by Chuah Hui Hsien » Wed Dec 26, 2018 1:26 am
Joachim,
Do you have any video clip showing how to tie the "stopper knot"? I would love to learn this method.
I've seen this knots on all the Yamaha guitars,but I couldn't figure out how they made them look so nice.
Post by joachim33 » Wed Dec 26, 2018 9:45 am
Joachim,
Search for overhand and figure of the eight knot. For nylon 3G strings I use an overhand knot (the figure of the eight gets to large) for the 1E (Nylon and Carbon) I use a figure of the eight. The rest depends on experimentation and the mood of the moment. I have a small pair of plier to tighten them.
decacorde
Post by decacorde » Wed Dec 26, 2018 3:15 pm
You can tie a knot at the end of the string as in the picture. I do it for all my guitars, nylon, titan or carbon strings.
Baloo
Post by Baloo » Fri Dec 28, 2018 9:48 am
Good to know!
The strings themselves are a revelation - what a difference. I wish there was some kind of hybrid for the top E, that's all.
Post by rojarosguitar » Fri Dec 28, 2018 9:56 am
Baloo, "been there, got that t-shirt", too. Consider it as the 'beauty mark' left by experience - if you have a ding.
As to the e-string: for me the carbon e is a no-go, sounds ways to bright. Augustin Regal e is the kind of hybrid you look for; also Dogal makes some hybrids. Soundwise is the Aquila New Nylgut also somewhere between Carbon and Nylon, but its white and quite conspicuous. Also nylon strings are not equal. Luthier e-string or La Bella, or Oasis, are all nylon strings on the brighter side of the spectrum.
There are several other methods preventing slippage, but it also depends on whether you have a 6 hole or a 12 hole tie block.
Post by rojarosguitar » Fri Dec 28, 2018 5:40 pm
I just posted this: https://www.classicalguitardelcamp.com/ ... 3&t=124635
This would be one possible method to avoid slippage problems with any strings if you have a 6 hole tie block. This kind of string beads heave also other advantages:
- the edges of the tie block are protected against strings cutting in, which is especially a problem with carbon strings, and especially carbon e-1, if you don't have a bone plate or at least bone edges.
- Also the string holes are protected better.
- the breaking angle of the strings is more even across the strings and always the same, when you change strings.
The guitar I have made the string beads for has (as nice as it looks, nonsensically) quite soft edges of the tie block.
On the first pic you can see also an additional protection of the portion of the top directly behind the bridge, in case something should happen. This is simply a piece of iPhone screen foil. It doesn't have any adhesive and sticks just like that to the varnish, if you rub it shiny before putting it on. It can be removed without slightest trace and still protects the top against some of the possible mishaps.
If you have a 12 hole tie block, of course no string beads are needed.
Steve Ganz
Post by Steve Ganz » Fri Dec 28, 2018 6:36 pm
Baloo,
Does your bridge have 6 or 12 holes?
Post by joachim33 » Sun Dec 30, 2018 7:38 am
Good picture. This looks very tidy.
Baloo
Post by Baloo » Mon Dec 31, 2018 10:30 am
6. The melted ball ends are holding so far. I will probably go with a nylon e next time and the e seems to be the main worry so that will solve it really.
Speaking of which:
The strings I have on at the moment are Savarez Alliance normal tension. How would I match a nylon e to the carbon G and B strings? The published tensions for the carbon strings are 5.8, 5.9 and 7.9 kg. Should I look for a nylon e that is about 6kg, or is that going to be too quiet by comparison?
