switching to new brand same normal tension but so hard
Thomas
Post by Thomas » Sat Dec 29, 2018 5:37 am
I used ej45 daddario for a long time and recently switched to Savarez 540R Alliance both are normal tensions but Savarez 540R Alliance seems to be harder for my fingers and the resquado seems to be harsher . What is your opinion about it?
guitarrista
Re: switching to new brand same normal tension but so hard
Post by guitarrista » Sat Dec 29, 2018 5:53 am
Naming characterizing tension is not standardized across string brands. Here's the actual info on the two sets you have, at the same scale length:
So the high E, the B, and the D have significantly higher tension. However, what you feel also depends on string diameter (smaller for Savarez trebles) and bending stiffness of materials which are different here - nylon vs. "carbon". So the smaller diameters of the Savarez trebles should also make you feel like they are higher tension. (I don't know how bending stiffness compares but it is possible its effect goes in the same direction).
Key message, though, is that "normal', "high", "low", etc. labels referring to tension cannot be used to infer tension across brands. Hannabach's low maybe close to D'Addario's high (don't know if this was the actual example but there is such a degree of mismatch between labels and tensions across brands).
The actual tension as put on the guitar also depends on the length scale (and companies do not quote tension numbers at the same length scale; or are silent at what length scale their numbers were measured/derived). So it is a bit of a mess. The only thing is that gradation of tension labels within one brand corresponds to set (or trebles set or basses set within) tension going in the implied direction.
Konstantin
1982 Anselmo Solar Gonzalez
Leo
Post by Leo » Sat Dec 29, 2018 6:20 am
I think he is talking about the Alliance strings which are carbon strings, you gave him tension levels for the rectified strings it seems to me. The Alliance are very high tension strings.
2012 Hippner, Spruce-birdseye maple
1985 Takamine C-132S
2002 Casa Montalvo, Spruce, Ziricote
Christopher Langley
Post by Christopher Langley » Sat Dec 29, 2018 6:26 am
As noted there is no consistency between brands.
Martin strings are the opposite. High tension is medium.
One of the reasons I like d addario. Their mediums feel medium to me.
Let there be songs to fill the air.
Chuah Hui Hsien
Post by Chuah Hui Hsien » Sat Dec 29, 2018 6:41 am
Thomas,
Savarez Alliance consists of 3 carbon treble strings, they are generally stiffer than their new cristal nylon counterparts.
If you don't favour stiffer strings, you gotta avoid carbon strings such as Alliance.I don't like them either, except for the compesational 3rd G string. You can try out D'addario EJ 46C that comes with a composite G string. I don't feel it hard tension at all if compares with Hannabach, Augustine Regal or Savarez.
guitarrista
Post by guitarrista » Sat Dec 29, 2018 6:46 am
I knew that but it seems the numbers I had have changed recently. I updated the image (and text) above with the current Savarez tensions they claim for KF Alliance normal tension trebles. Thank you for pointing this out.
Konstantin
Thomas
Post by Thomas » Sat Dec 29, 2018 8:13 am
Thomas,
This is what I put on my guitar it says NORMAL but it does not feel so normal :)
My guitar sacle is 650 mm
Is this string Carbon? Man I did not know . I hate carbon any way
Chuah Hui Hsien
Post by Chuah Hui Hsien » Sat Dec 29, 2018 8:29 am
Yes, it is not Normal 😁! It is only appealing to those who favour bright carbon strings sound and who likes to play thin and stiffer strings.
Savarez Corum/Cristal 500cr,New Cristal Classic 540cr and New Cristal Cantiga 510cr should be okay for you. Don't buy the "cj", this refers to Hard Tension, it is going to be tighter on 65cm scale guitar.I even found them hard on my 64cm guitar,although this tension sounds great on it.
Post by petermc61 » Sat Dec 29, 2018 8:57 am
Thomas
If you would like to stick with Savarez strings at this time yet the normal tension (NOT high) Cantiga Creation set. They will feel better and in my experience sound better too.
Peter
Thomas
Post by Thomas » Sat Dec 29, 2018 9:30 am
Thomas
Peter
Thanks Peter
Do you mean this one?
Chuah Hui Hsien
Post by Chuah Hui Hsien » Sat Dec 29, 2018 9:47 am
Be informed the Cantiga Creation set consists of carbon on the 3rd string. E and B cristal nylons, cantiga bass strings.
Post by petermc61 » Sat Dec 29, 2018 10:10 am
Thomas
Peter
Thanks Peter
Yes, that’s it. As mentioned above carbon G but nylon b and e, coupled with the best basses I have heard from Savarez.
Post by celestemcc » Sat Dec 29, 2018 4:57 pm
Alliance are carbon. This is another of the newer mixed sets they're doing, Cristal/Cantiga/Alliance G. I'm currently using HBs and I still use an Alliance G with them.
Post by joachim33 » Sun Dec 30, 2018 7:56 am
Thomas
Peter
Thanks Peter
I had two sets of those on two different guitars. With me New Cristal trebles (1E and 2B of this set) raise in pitch after a few minutes of arpeggios, while the Carbon 3G does not, neither do the basses. I am returning very frequently with these. I was more happy with the 510CR (all New Cristal). Here all trebles raise.
I asked about the raising of the trebles some time ag anc got the answer this is normal for traditional nylon strings. I tried a few other brands of nylon trebles and they all do to some extent. I was told that Carbon strings do not do this and have confirmed that with s full set of Savarez 510 ARJ.
I currently have a set of Aranjuez Suave A800, which I find quite tolerable in that respect. The 2B seems to raise the most, while the 3G does not raise as much - to my surprise. The 4D also raises a little. In summary I find the detunining more tolerable and do not retune so much.
Post by joachim33 » Sun Dec 30, 2018 7:58 am
Thomas,
Are these your first Carbon strings? I recommend you to give them time to develop. They need time under tension to sound their best.
