Unknown composition
This forum is for our discussions on any classical guitar works. Regardless of whether these works are still under copyright, we can illustrate our discussions with extracts to a maximum length of 8 bars or 30 seconds, using attached audio files (mp3, wav or wma) or video files (mov or wmv). Only attached files are permitted. Links to audio and video files are not allowed.
This forum is for our discussions on any classical guitar works. Regardless of whether these works are still under copyright, we can illustrate our discussions with extracts to a maximum length of 8 bars or 30 seconds, using attached audio files (mp3, wav or wma) or video files (mov or wmv). Only attached files are permitted. Links to audio and video files are not allowed. However, we can say in our posts "you can hear a model interpretation by such and such a guitarist on such and such a site".
This forum serves as a place of mutual help if we are stuck on a technical or musical difficulty, whether the problem stems from the notes, the rhythm, the dynamics, or the fingering. We can post several successive versions of the extract, as our work on it progresses. This will serve to help not only the member who is presenting his work, but also indirectly the dozens of other members who are having the same issues with the same passage, but who don't have the equipment or the technical knowledge to post a recording.
As a rule there should be just one topic per work. If several discussions arise on the same work, the moderators will merge the threads together.
Evan
Unknown composition
Post by Evan » Mon Dec 31, 2018 3:10 am
Hi All,
Can anyone help with the title and composer of this piece? A friend of mine learnt it by ear many years ago, supposedly from a Segovia cd.
Evan
Evan
Re: Unknown composition
Post by Evan » Wed Jan 02, 2019 1:30 pm
viewtopic.php?f=1&t=124673&p=1328369#p1328369
Just putting this here because it has been solved in another thread. Thanks to all who contributed.
Return to “Extracts of works in progress, 8 bars or 30 seconds maximum”
