Changing bitrate and sample rate on existing cubase project
Arash Ahmadi
Post by Arash Ahmadi » Wed Jan 02, 2019 8:14 pm
Cubase usually asks whether changing the bitrate and sample rate to 16 and 44.100 once you drop an audio file. I didn't tick them... :? The project is almost finished now but I need to change it to 16/44.100. How can I do that?
Becoming a great musician is about becoming a great human being.
Arash Ahmadi
Re: Changing bitrate and sample rate on existing cubase project
Post by Arash Ahmadi » Thu Jan 03, 2019 8:43 am
Found the way! Here's how, in case anybody else is wondering:
In the upper bar, one can see the bit-rate. Once you click on that a window opens where bit-rate and sample rate can be changed. For me it showed the desired bit-rate but was actually something else... So I had to convert it to 48 first and then convert it to 41 again. That was the trick!
PeteJ
Post by PeteJ » Mon Jan 28, 2019 2:56 pm
I'm not sure what you mean here. The project settings never need to change and you can bounce files at any spec you like, dithering as appropriate. By 'drop' do you mean 'bounce'.
Arash Ahmadi
Post by Arash Ahmadi » Fri Feb 15, 2019 2:04 pm
By drop I mean insert but I don't know what you mean by bounce... are we talking cubase?
PeteJ
Post by PeteJ » Sat Feb 16, 2019 9:43 am
I wasn't sure whether you meant the bitrate of the project or of the mix (bounce). It's very unusual to change the project bitrate for a work in progress and rather dangerous, but necessary to do so for the mix. The mix can be bounced at whatever specs you want. Do you mean bit and sample rate of the project or of the mix?
Wuuthrad
Post by Wuuthrad » Sat Feb 16, 2019 9:57 am
I think the original question was regarding how to insert audio into an existing project, and needing to match the rates, but not about the bouncing or mix down stage.
"Pay no attention to what the critics say. A statue has never been erected in honor of a critic." -Jean Sibelius
PeteJ
Post by PeteJ » Sat Feb 16, 2019 12:47 pm
Oh okay. Usually I'd let the system convert the audio insert to the project rather than the other way around.
Arash Ahmadi
Post by Arash Ahmadi » Sat Feb 16, 2019 4:10 pm
Right :)
