String ties
pasigenyo
String ties
Post by pasigenyo » Tue Jan 08, 2019 3:25 pm
I just used a set of string ties that were given to me by my luthier for the first time. I'd like to find out if anyone uses these on a regular basis and what their thoughts and experiences are. Aside from preventing scratches on the guitar top (when the strings suddenly slide off the bridge and lashes the soundboard), did these contribute to any changes/improvements to the guitar's sound and/or the strings' tension? Thanks in advance.
Beowulf
Re: String ties
Post by Beowulf » Tue Jan 08, 2019 3:53 pm
I use them and have for years. I have not noticed any change in the sound, however I do experience a slightly greater resistance to right hand finger strokes. The strings recover a bit more quickly after being displaced. I like this. Whether or not you do will depend on your instrument and right hand technique.
brad4d8
Re: String ties
Post by brad4d8 » Tue Jan 08, 2019 4:21 pm
I use them, have for a few years. Got them to see if there was a difference in sound or playability. Not sure if there is any, but I have them, so I use them.
Brad
Steve Ganz
Re: String ties
Post by Steve Ganz » Tue Jan 08, 2019 5:12 pm
Let me just point out that if the holes in the bridge's tie-block are low enough, these little buttons will touch (or even press down on) the top of the guitar.
If this is the case, it's probably not enough to really hurt the guitar, but it's probably also not necessary.
pasigenyo
Re: String ties
Post by pasigenyo » Wed Jan 09, 2019 2:41 pm
Thanks for the feedback. So far, I have the string ties on for about 3 days and I feel the string tensions are a bit looser (i.e. not good). Not sure how exactly to describe it, but the trebles now sound a bit metallic. Rather than increased resistance, I feel the strings vibrate all over the place and are harder to manage while playing. These may just all be in my head, but I may just take them off and go back to tying the strings on the tie block.
Beowulf
Re: String ties
Post by Beowulf » Wed Jan 09, 2019 3:47 pm
This may have to do with the design of the ties you are using: they extend rather far out from the back of the tie block and may not be quite as secure as other designs. Check out the Rosette String Ties:
nmshu1
Re: String ties
Post by nmshu1 » Wed Jan 09, 2019 4:28 pm
I tried and compared. It depends on your preference. Anyway, it is easier to change strings.
Same feeling, the strings are looser. Looks like strings' tension lower. I prefer to lower strings' tension.
Otto Vowinkel Concert | Paulino Bernabe Torres | Juan Hernandez Torres | German V. Rubio Concert | Kenny Hill Performance
pasigenyo
Re: String ties
Post by pasigenyo » Thu Jan 10, 2019 5:50 am
I suspect the same thing. Thanks.
