Very good metronome app
Post here only items useful for reference purposes.
Madeleine Pashkofsky
Post by Madeleine Pashkofsky » Tue Mar 17, 2015 7:20 pm
Last night while practicing my Delcamp lessons I discovered I had forgotten my stand alone metronome. So I went to the App Store on my iPhone and found one that I really like. It's called "Metro Timer". It's free though the paid version adds some additional functionality. I am just using the free version but I like that you can set different types of clicks, include a flash or not on the downbeat, and you can subdivide the beats. I think my practice went better because I was able to set a 2/4 beat with eighth notes.
Mark Featherstone
Re: Very good metronome app
Post by Mark Featherstone » Fri Mar 20, 2015 5:15 am
I've been using it too. But from what you say, I clearly don't make full use of it. What do you mean by "you can subdivide the beats".
Thanks,
Mark
Francisco Navarro Concert Classical, cedar top, 630 mm scale, 50 mm nut
"The trouble with normal is it always gets worse."
Bruce Cockburn
Post by Madeleine Pashkofsky » Thu Mar 26, 2015 5:58 am
Baoyu wrote:I've been using it too. But from what you say, I clearly don't make full use of it. What do you mean by "you can subdivide the beats".
Thanks,
Mark
By that I mean setting an overall time signature, like 2/4, but then setting the clicks to play 8th notes. I find this very helpful with learning timing of tricky passages.
wilhelmreich
Post by wilhelmreich » Thu Mar 26, 2015 6:43 am
Looks like it's a good app. Does someone know an Android app, that can subdivide the beats (very useful, especially for slow pieces), but also switch between 6/8 and 3/4 - I still don't know how to practice Lauro fast pieces with metronome. The only solution is to set clicks on the eigths, but if the speed is too fast, it's not practicable. There must be an app, where you can set "play one bar with one click per two eights and play the next bar with one click per three eights".
Mark Featherstone
Post by Mark Featherstone » Thu Mar 26, 2015 8:00 am
Thanks,
Mark
Ah, I see how it works now. I didn't think I could do that in the free version. Thanks!
Bruce Cockburn
JeffR
Post by JeffR » Sat Mar 28, 2015 8:44 pm
Check out Time Guru. It costs a couple of dollars but it does a lot. For Android or Apple.
alvynmcq
Post by alvynmcq » Wed Apr 08, 2015 10:24 pm
I have been using Clockwork on my iPhone and have found it to be excellent. The same company also produces cleartune which is an excellent tuning app.
Cary W
Post by Cary W » Thu Apr 09, 2015 1:48 am
wilhelmreich wrote:Looks like it's a good app. Does someone know an Android app, .
Try Metronome Beats...from Google play store...works for me.:-)
2008 Yamaha GC31C Indian/cedar D'Addario EJ46
1987 Yamaha GC-3 Indian/cedar D'Addario EJ45
BrunoGS
Post by BrunoGS » Sat May 09, 2015 5:04 am
Mobile Metronome [android] is pretty good.
skipneumann
Post by skipneumann » Thu May 19, 2016 4:42 am
"Pro Metronome" by Xiao Yixiang iphone great tuner also available
wortspur
Post by wortspur » Thu May 19, 2016 10:30 am
I also use "Pro Metronome".
Especially like the training mode where you can select a start tempo, an end tempo, the duration (bars) of each bpm and increase in speed.
For example: Beat 3/4, time signature 16th notes, start tempo: 42 bpm, increase tempo by 2 bpm every 8 bars until the end tempo of 100 bpm is reached.
Jack Douglas
Post by Jack Douglas » Thu May 19, 2016 12:22 pm
Hi Madeleine,
I downloaded the paid version and at first glimpse find it very good. Subdivided beats will be very helpful for me. Thanks for the tip.
Jack
Matt Molloy
Post by Matt Molloy » Thu May 19, 2016 2:16 pm
Another vote for Metronome Beats Pro here. Wish this had been around years ago (entirely too many metronomes destroyed in my musical progress).
"I'm playing all the right notes, but not necessarily in the right order." Eric Morcambe
Proud member of the LGCI.
Guitar: James Lister 2009 SP/MP.
Luis_Br
Post by Luis_Br » Mon May 23, 2016 4:52 pm
I've been using Metronomerous for Android. Its free and has a lot of configuration. You can subdivide, put pauses, delays, speed and sound variation etc. You can practically build up a drumming session with it. I like the ability it has to configure so it plays a measure then it keeps some measures without playing (you configure how much). So you listen to the metronome eventually, to check if you are keeping time.
philip caldwell
Post by philip caldwell » Sun Apr 15, 2018 5:02 am
you lot are not thinking this through. A click on a metronome is any value you want it to be. it's not the machine that 'subdivides' the beats, it's you . in your head. For example if you have it set to 100 bpm as crotchets and that's far too fast then imagine it as beating quavers so it's not going 1 2 3
it's going 1 and 2 and 3 and. Now it's at 50 beats a crochet. Do you see? On passages with lots of runs in quavers or semi quavers it's not useful to have a click on each note, Set it to 1 beat for each group of 4 for example.
Return to “Reference Library”
